Array data type
I just upgraded to Ignition today and have a problem with some of my data. You can follow the link below to see what the data looked like in FactorySQL.
http://www.inductiveautomation.com/forum/viewtopic.php?f=15&t=3717
When the group was in FactorySQL the item had an array type definition. I could not find this in Ignition and it was defined as a string after the import. Now I get an [quote]OPC_BAD_DATA[/quote] in the value.
I am unable to reference each element of the array separately in the OPC server.
Is this a configuration/upgrade issue or a feature request?
Thanks,
Yes, array support is an issue that we’re aware of. Unfortunately we don’t currently have a good work around- I’ll have to look into to what the status is on getting arrays to work.
Regards,
