No, I was missing something. The manual does not mention tag properties in the function call syntax or example. So I can now globally assume whenever tagPath is a function parameter that ALL properties are available to that function? If so, I can work with that. Looking forward to returned datasets for these functions.
Still need the ability to query SQLTag properties based on other SQLTag properties, such as:
Return a dataset (based on a partial or full tagPath), with a list of returned properties I need, where AlertExecEnabled = 0.
I appreciate all you do to make Ignition robust and SI friendly!
