I currently am using Container for making Ignition GUI. It is used to contain long lists of signal.
[attachment=0]signal2.png[/attachment]
As the number of signal gets higher, the Container cannot show all of them anymore. Is there any way to have something like Vertical Scroll Bar in Ignition?
Ah yes, I almost use that. But the thing is, the list contains something else than rather just one time item (not just signal).
If you notice, There is a Close label in the top left of the Container used to close the Container when the user clicks on it. So, the Container contains more than just one template.
I am wondering if there is any solution like Java’s JFrame or WinForm’s/WPF’s StackPanel in Ignition. If there isn’t any, I would also like to know if there is any workaround.
@pturmel: ah yes, I forgot to mention that a Label is in the list (besides the signals). Thanks for the clarification.
@JGJohnson: In the end, I choose to pick that solution. Not exactly what I want since, without work around, it will create boundary between the Close label and the Template Repeater. But that’s fine. What I originally make is a Label with a boundary having Text, “Show” and then as you click on it, the Label is hidden and is replaced with the Container with Label “Close” in the top most - creating the effect of “expanding” rather than “opening”. When I separate the Close Label from the Template Repeater, I would need to create a customized boundary to preserve the “expanding” effect. But yeah, in the end I choose the easier solution.
