…sPortName is a string value = “COM5”.
…gateway goes to stopped. And Web Server goes stopped too. Helpful only the restarting Ignition Gateway service to launch project.
The fix will be in 7.6.5-rc3, which comes out around the middle of next week. The serial modules aren’t included in the installer, so be sure to download new versions off the Ignition downloads page when the release comes out.
Will test tomorrow. But… If the modules not upgrated when the Ignition goes to update? We have the step, when we must to choose “Update installed modules” or “Select, which modules must be installed”. So, when we choose “Update installed modules”, serial module must updating to?
No, issue still have. I was reinstall serial modules (client and gateway) after downloading from market.
Ignition still crashing after trying to open port.
Can you verify for us the versions of the modules that you installed?
If you go to the Gateway, under the Status tab, choose Modules and scroll down to the Serial modules. Copy and paste everything on the line “version” for both modules.
