Articles
Expand your knowledge with guides, industry articles, and white papers.
The Purdue Model And Ignition
In the automation world, the Purdue Model (also known as the Purdue reference model, Purdue network model, ISA 95, or the Automation Pyramid) is a well-known architectural framework for industrial control systems (ICS).
4 min read
UNS: Unified Namespace
Digital Transformation is all about data, and companies will only achieve this goal if they manage their data differently than in the past. A Unified Namespace (UNS) is the architectural foundation of successful Digital Transformation initiatives because it enables you to make data accessible from your entire enterprise to a single database.
7 min read
What Is MES?
Simply put, a MES system is used to monitor and manage work-in-process on the factory floor, covering resource scheduling, production workflows, recipe management, traceability, inventory, quality assurance, document control, and more. A successful implementation of MES software will not only improve efficiency, but make manufacturers into better businesses.
4 min read
NERC CIP Best Practices with Inductive Automation and Ignition
This guide addresses best practices for using Ignition and working with software vendors in a CIP-compliant way, with recommendations based on specific CIP standards.
1 min read
Using Keycloak with Ignition
Keycloak is an open-source Identity and Access Management solution for adding authentication to applications or services. With Ignition, Keycloak functions as an Identity Provider to authenticate users and define roles to access client/session views.
10 min read
What Is a Panel PC?
Most people are familiar with PCs (Personal Computers), but far fewer understand the difference between a retail PC and a panel PC. Whereas PCs are typically found in offices, panel PCs are specialized units designed to be used on or near machines in industrial environments like plant floors or remote sites. Panel PCs are built specifically to run HMI/SCADA software that allows operators to monitor and control processes in virtually every industry, including food & beverage, oil & gas, automotive, water & wastewater, and many more.
4 min read
21 CFR Part 11 and Pharmaceutical Best Practices with Ignition
This guide addresses Food and Drug Administration (FDA) 21 CFR Part 11, Data Integrity and Good Automated Manufacturing Practices (GAMP). It provides best practices and guidelines supporting regulated Ignition applications in the life sciences and pharmaceutical industries.
1 min read
Digital Transformation: Your Guide to Business Success
Digital Transformation is not just a buzzword or a passing fad businesses can afford to ignore. It’s the evolution of business.
12 min read
What SCADA Systems Need in the Modern Era
Learn about the features you need to guarantee that a SCADA system is powerful and flexible enough to excel in the modern era.
10 min read
Ignition Server Sizing and Architecture Guide
This guide is intended to provide some tips to help you determine the correct architecture depending on your requirements. It is important to note that any architecture that you come up with needs to be fully tested and verified. Throughout that process you can observe the performance characteristics of the server in order to make any necessary adjustments to the architecture. There is no guarantee on performance since it is based on your design choices.
33 min read
Ignition 8 Deployment Best Practices
Inductive Automation provides this helpful guide for deploying Ignition applications. The guide offers Ignition 8 best practices for setting up development and testing workflow.
30 min read
PLC: Programmable Logic Controller
Learn Programmable Logic Controller (PLC) basics: what it is, what its functions are, how it operates, and its importance in the world of automation.
8 min read
