From Flexibility to Future-Ready: The Power of Ignition Solution Suites
Every solution begins with a platform, and with Ignition, that platform is modular and without limits. Its architecture is designed for flexibility, giving you the freedom to build the exact system you need. From day one, Ignition has empowered teams to connect, design, and scale without boundaries.
Now we’re taking that modular strength and making it even easier to apply. With Ignition Solution Suites, you get pre-built combinations of modules designed to deliver complete, future-ready solutions, so you can accelerate deployment today and be ready for whatever comes tomorrow.
From Modular Power to Ready-Made Solutions
Ignition gives you unlimited licensing and an extensive library of modules. But deciding where to start can sometimes feel like too many choices. Solution Suites simplify that first step.
Each suite takes Ignition’s modular flexibility and packages it into a curated, real-world solution: specifically focused, ready to deploy, easy to expand, and always adaptable. This way, you can start with confidence while keeping the full flexibility of Ignition intact.
What Are Solution Suites?
Ignition Solution Suites are curated collections of Ignition modules designed around the most common industrial needs. They’re modular by nature, which means you can deploy them individually, combine them with each other, or extend them with additional modules, all while keeping Ignition’s unlimited potential.
At first glance, Solution Suites might appear to just be a bundle of modules. But when you purchase Upgrade Protection with Solution Suites, you're entitled to all upgrades for that suite in the future for free. This brings Ignition's unlimited licensing to a whole new level.
Here are the five Solution Suites you can choose from today:
1. The Application Building Suite
If you are developing custom human-machine interfaces (HMI) or real-time dashboards, this module suite is perfect for your system. It has everything you need to build modern industrial applications, generate flexible reports, and turn raw data into meaningful insights, including the Perspective Module and the Reporting Module.
2. The Industrial Historian Suite
This module suite enables you to do historical trending and analysis, manage large volumes of time-series data efficiently, and query data. It includes the Historian Core and SQL Historian modules.
3. The DataOps Operations Suite
With this module suite, you will be able to break down data silos, create an event-driven architecture with real-time updates via MQTT and seamless SQL integration, facilitate seamless data flow between OT and IT systems, and use custom web development tools. It includes the SQL Bridge Module, the Event Streams Module, and the Web Development Module.
4. The Alarm Management Suite
This notification suite simplifies operations struggling with alarm fatigue or complexity by providing robust tools for alarm configuration, advanced notification paths, and escalation workflows to ensure critical issues are addressed quickly and effectively. It includes the Alarm Notification, Voice Notification, SMS Notification, and Twilio Notification modules.
5. The Enterprise Integration Suite
With this module and connector combination suite, you will be able to bridge plant-floor systems with enterprise applications, utilize real-time data sharing through MQTT and Sparkplug B, and connect to databases like MongoDB and Kafka. It includes the modules and connectors required to to securely move data across your enterprise, ensure interoperability between OT and IT, and empower decision-makers with accurate, real-time information.
You can start using these first five Solution Suites now, and look forward to additional updates and new options coming soon.
Get Started With Solution Suites
Here’s why Solution Suites are a great choice, both in the short term and the long term:
- Future-Ready by Design: As Ignition evolves, so do Solution Suites. When new modules or features are added to extend the capabilities of a suite, those enhancements become part of the package. And with an optional support plan, you’ll receive every upgrade and new feature automatically, at no additional cost.
- Accelerates Deployment: Suites cut through complexity, reduce debate over what to buy, and get you to value faster.
- Flexible Without Limits: Start simple, add more suites, or extend with individual modules. You never lose the modular power of Ignition.
And just like Ignition and its modules, Solution Suites are presented with transparent pricing right on our site, so you always know exactly what you’re getting.
Because when it comes to industrial automation, it starts with Ignition, and now it starts faster with Solution Suites. To learn more, click here.
