The Suite Spot: Meeting Your Needs Now and Later
In industrial automation, today’s decisions often define tomorrow’s limitations. If you get the wrong software, you might outgrow it in a year. If you build a system too rigidly, scaling can become costly. That’s why we created Solution Suites: curated collections of Ignition modules that strike the sweet spot between structure and flexibility.
Solution Suites offer a strategic starting point that allows your system to evolve with your specific needs. Each suite gives you a purpose-built collection of tools, carefully chosen to solve real problems right away, while still offering a clear, modular growth path for future requirements. This makes Solution Suites the best way to start configuring Ignition, delivering the core features and functionality you’ll need to realize its full potential from day one.
Solution Suites in Action
There are currently five Ignition Solution Suites, and each suite is tailored around a key industrial use case.
- The Alarm Management Suite: For robust, multi-channel alarm notifications and escalation logic.
- The Application Building Suite: For real-time dashboards, modern HMIs, and flexible reporting.
- The Industrial Historian Suite: For scalable, high-performance time-series data storage and visualization.
- The DataOps Operations Suite: For bridging OT and IT, integrating SQL, and building event-driven architectures.
- The Enterprise Integration Suite: For connecting plant-floor systems to ERP, cloud platforms, and beyond.
These suites simplify your starting point, reduce guesswork, and accelerate deployment. You keep the infinitely modular power of Ignition, with the added benefit of curated and structured solutions that support growth and change.
Here are three examples of how these Solution Suites could help you in the real world.
Manufacturing: The Alarm Management Suite
Let’s say you’re a mid-sized manufacturing operation, and you’ve purchased the Alarm Notification Module to help your team stay on top of critical events. It works perfectly until the business starts to grow and you need more capabilities.
Now you’re dealing with multiple facilities, escalation workflows, mobile teams that need SMS and voice alerts, and integration with different software and platforms. Then your solution starts to feel like a patchwork as you bolt on additional modules and write custom scripts. As your alarm system gets more complex, the risk of a serious problem ‘falling through the cracks’ increases.
If you had started with the Alarm Management Suite, you’d already have:
- Multiple notification options with alarm, voice, and SMS modules
- The Twilio Module, for both voice and SMS (if your organization prefers Twilio)
- Tools for alarm configuration
- Advanced notification paths
- Built-in escalation workflows to address issues quickly
- A future-proof foundation designed to scale with operational complexity
- A clear upgrade path for all suite components under one support plan
By starting with Solutions Suites, you’re not just solving today’s problem — you’re setting up for tomorrow’s success.
Food & Beverage: The Application Building Suite
Assume you are a regional beverage company that began modernizing its operations by using the Perspective Module to build an HMI for one production line. As the company expanded, so did the need for a unified view of KPIs across multiple facilities and product lines. What started as a simple display project quickly turned into a sprawling mix of screens, queries, and duplicate data structures. This can become hard to maintain and even harder to align across departments.
If you had started with the Application Building Suite, you would have been able to use:
- The Perspective Module, with tools for building scalable, mobile-ready HMIs and dashboards
- The Reporting Module, enabling compliance and performance tracking
- A unified framework to reuse visual components and data models
- A foundation to extend into enterprise-level visualization as you grow
By starting with this suite, you could have gone from local visibility to enterprise-wide transparency without spending valuable development time reconfiguring your system.
Water Utilities: The DataOps Operations Suite
For our last scenario, you are a public water utility that implemented Ignition to replace manual data collection and automate basic system monitoring. Initially, you used the SQL Bridge Module to log pump runtimes and flow rates. That helped, but over time, the utility needed real-time notifications, integrations with their GIS and CMMS platforms, and better data governance across distributed sites.
With the DataOps Operations Suite, you would have had:
- The SQL Bridge Module connecting PLCs and databases
- The Web Development Module for internal web apps and custom visualizations
- Event-driven data architecture to reduce polling and improve responsiveness with the Event Streams Module
- Seamless OT/IT integration through MQTT and SQL
- A scalable structure to expand into multi-site asset tracking and performance benchmarking
Instead of stitching together point solutions, you could have a clean, modern data infrastructure that grows with your system from the start.
Built for the Journey, Not Just the Launch
The most exciting thing about Solution Suites for growing companies is that they are not static products.
As Ignition evolves with new modules, integrations, and features, so do Solution Suites. When you choose a suite and pair it with Upgrade Protection, you automatically receive future modules and enhancements to that suite at no extra cost. That means your system grows alongside your business, without surprise fees or complicated license changes. Also, you can add new modules at your own pace, test new features with the two-hour Ignition free trial before they are added to your suite in an update, combine multiple suites for more complex systems, and scale from a single site to a global enterprise without reworking your architecture.
Start With Confidence and Scale Without Limits
Whether you’re launching a new facility, modernizing legacy systems, or laying the groundwork for Digital Transformation, Solution Suites give you a strong foundation and the adaptability to grow without rebuilding from scratch.
Every smart system starts somewhere, and the right starting point makes all the difference. Solution Suites offer the clarity, flexibility, and foresight that teams need to make smart decisions now and avoid technical debt later.
In automation, where you begin matters, but where you are headed is everything. So why not start in the suite spot? Explore Solution Suites and get started quicker with Ignition!
Tags /
Alarming Food and Beverage Water/Wastewater SQL SQL Bridge Module OT-IT Modules HMI Dashboards Mobile Support
