Ignition: The Perfect Platform For IIoT
Tomorrow's Integrated IIoT & SCADA Platform is Here Today
Get started with Ignition IIoT
Ignition by Inductive Automation® is the only IIoT platform with full-featured SCADA functionalities built right in.
The Ignition Platform
The first universal industrial application platform
Ignition is the world’s first truly universal industrial application platform because it empowers you to connect IIoT data across your entire enterprise, rapidly develop any type of automated system, and scale your system in any way, without limits.
Unlimited licensing model:
Add unlimited clients, screens, tags, connections and devices
Cross-platform compatibility:
Ignition works with any major operating system
Based on IT-standard technology:
Built on Java, Python, SQL, MQTT, & OPC-UA
Modular configurability:
Customize to any process or industry with SCADA, MES & IIoT modules
Scalable server-client architecture:
Easily deploy at one or more sites or in the Cloud
Web-launch on desktop or mobile:
Use it on any web-enabled PC or mobile device
Ignition’s Modular Configurability
What Makes the Ignition IIoT Solution Unique?
Manufacturers around the world use Ignition to efficiently connect devices, systems, and people over the web. By plugging SCADA modules into the Ignition platform, users can add features such as charts and tables, mobile access, voice notifications for alarms, sophisticated logic systems, and many more.
The Cirrus Link MQTT Modules for Ignition leverage all of Ignition’s unique, industry-leading platform features, which can easily connect the devices in your enterprise and viably harness data for maximum benefit. With Ignition's unlimited licensing model, you can affordably collect and process massive amounts of data and scale out your system. Like all Ignition modules, the Cirrus Link MQTT Modules for Ignition can be installed, removed, and upgraded without impacting operations or affecting the rest of the system.
Ignition: The Ideal IIoT Platform
3 Reasons Why Ignition is Perfect for IIoT
Inductive Automation's Founder & CEO, Steve Hechtman on the benefits of Ignition and IIoT from ICC 2015
Ignition is the ideal platform for making the IIoT a reality. It has three core elements in particular that set it apart as an IIoT platform: open connectivity, unlimited storage, and agile applications.
1. Open Connectivity
Ignition's integrated OPC Unified Architecture (OPC-UA) server provides near-seamless connectivity to hundreds of protocols. Its open application programming interface (API) facilitates interaction and data-sharing between applications, and the development of drivers for protocols such as MQTT.
2. Unlimited Storage
Ignition leads the industry in database accessibility and utilization by unlocking the power, speed, ease of use, flexibility, and superior economics of SQL databases. The ability to use Ignition at any scale — whether embedding it on a machine or hosting it in the Cloud — gives you wide latitude to scale your data storage.
3. Agile Applications
Ignition provides the tools to build agile applications that get collected data to the right people quickly. Ignition removes the obstacles of slow development, limits on user seats and data access, and unmanageable deployment with its unlimited user seats and data, and super-fast application development and deployment.
Ignition is the only unified SCADA and IIoT platform that empowers your enterprise to actualize the potential of the IIoT by rapidly developing, deploying, upgrading, improving, and scaling solutions. This is why Ignition is the world’s first universal industrial application platform.
