Ignition® IIoT Solution
The Best Industrial IoT Software for Efficiency, Connectivity & Data Insights
Identify IIoT plans to connect people and processes
Schedule a demo
Ignition IIoT: The Building Blocks of Your Digital Transformation
Ignition IIoT is an end-to-end Industrial IoT solution that combines the amazing efficiency of the MQTT data-transfer protocol with the unlimited data acquisition and development power of the Ignition industrial application platform. Revolutionize your industrial operations with increased connectivity and better data. Ignition's IIoT software connects enterprise hardware and software all the way from edge devices to the cloud. It also collects more data to feed advanced analytics like machine learning and artificial intelligence that maximize production and minimize downtime.
Benefits of Using Ignition IIoT (Industrial Internet of Things):
Unlimited Connectivity:
Use unlimited licensing to connect all equipment and technology across all facilities and in the field, and remotely monitor operations and control equipment from anywhere on any device.
Scalable Architecture:
Bring all enterprise assets together in one cloud-ready platform for a stable yet flexible architecture to build or improve upon, one module at a time.
Decouple Devices and Applications:
Leverage the power of MQTT to make all your data accessible through a pub/sub architecture to create a streamlined data pipeline for your whole enterprise.
Automation:
Upgrade manual tasks to analytics-driven automated processes that bypass human error, increase safety and cyber security, and boost efficiency.
Data Collection & Analytics:
Gain real-time data from devices and build custom reports for actionable analytics that drive more efficient production and better planning.
Work with IIoT Experts:
Inductive Automation partners with Cirrus Link Solutions – IIoT experts for more than twenty years, and the authors of the Sparkplug Specification – to leverage the full power of MQTT to create enterprise-level IIoT solutions.
"I've waited 17 years for a platform like Ignition to come along. Now with MQTT and Ignition, IIoT is a reality."
– Arlen Nipper
President/CTO of Cirrus Link Solutions & Co-Inventor of MQTT
How the Ignition IIoT Platform Works
The Industrial Internet of Things (IIoT) applies the principle of the Internet of Things (IoT) — a group of connected devices that exchange data over the Internet — to an industrial environment. Ignition sits in the middle where IT and OT converge, connecting your intelligent devices and industrial equipment to form a highly efficient pipeline of data. Leverage Ignition as a single solution and single source of truth to bridge device data with your SCADA systems or HMI screens and to visualize data as dashboards and reports.
See how ARB used MQTT to improve data utilization by 35%Adding the Power of MQTT Technology to Ignition
Ignition uses MQTT, the leading messaging protocol for the IIoT. MQTT was designed specifically to meet the demands of industrial control systems; it’s extremely lightweight, bidirectional, stateful, and secured with TLS technology. In developing our IIoT solution, we partnered with Cirrus Link Solutions, with years of experience developing top-quality IIoT solutions using MQTT. With software modules for transmitting data from the field via MQTT, launching an MQTT server in the cloud, and connecting that data to industrial and business applications, adding the Cirrus Link IIoT modules to the Ignition platform gives organizations the power to create their Industrial IoT networks.
Learn more about Cirrus Link ModulesUsing a Simple IIoT Architecture for a Scalable Solution
Ignition is an edge-to-cloud, floor-to-enterprise platform flexible enough to bridge your physical devices and digital data locally, in the cloud, or a hybrid of the two. There are many ways that an Ignition IIoT architecture can be deployed, but there are four main features to every Ignition IIoT architecture.
Publish Data from The Network’s Edge
With Ignition IIoT, you can connect to virtually any PLC or device, and transmit and receive edge-of-network data in multiple ways. READ MORE
Publish and Subscribe to Data Through MQTT
Ignition has several ways to securely connect, publish, and subscribe to MQTT data including launching its own MQTT server or connecting to compatible ones. READ MORE
Connect Ignition to an MQTT Server
The Ignition MQTT Engine Module gives Ignition the ability to bidirectionally communicate with an MQTT server and share that data with any Ignition client.
Build and Deploy Ignition Applications
With Ignition, you can build an MQTT infrastructure, design any kind of industrial application, and deploy it to any number of Ignition clients across your enterprise.
“The broad capabilities of Ignition allowed XOCEAN to build a web-based system with improved functionality and a better user experience.”
– Ruairi Daly
XOCEAN
See how XOCEAN leverages Ignition to build an architecture that's flexible, agile & scales quickly
Watch the case studyMajor Features
What Can You Do With Ignition IIoT?
Ignition IIoT moves at the speed of real-time data to reveal insights and direct your data where it’s needed. Its data monitoring and remote operations control capabilities reach far across your enterprise to improve production, maintenance, and sales.
Connect More Devices & Manage Them More Easily
Call Ignition “the Data Whisperer.” The Cirrus Link MQTT modules tame the complexity of integrating your local devices with SCADA systems and sharing data analytics through cloud solutions. Or, use the built-in Designer to develop and deploy custom web-based modules that easily connect sensors, create or import tags, and provide greater visibility over your enterprise.
Collect More Industrial Data & Make Better Use Of It
Like a cowboy ropes cattle, Ignition rounds up data from edge devices and builds a network of real-time data points. Our Reporting Module identifies period-based trends and creates event-driven reports for better, faster decisions. And, the accuracy of the data drives automation that reduces manual process and hand entries that lead to error, and minimizes the sources of security breaches.
Visualize Data From Applications in Customizable Dashboards
Make sense of complicated data. Ignition’s Vision Module launches clients from a browser and displays application data in a variety of charts, graphs, and dashboards using customizable graphics that resemble real-life objects. The Perspective Module is mobile-responsive and runs natively in a web browser to display data in an easy-on-the-eyes format.
“Ignition is solving the problems of being able to see your content across an entire fleet.”
– Chris McLaughlin
Vertech
Learn how Vertech visualizes data with dashboards to see the big picture across six solar locations
Watch the case studyEasily Build a Unified Namespace in Ignition
Ignition SCADA and Cirrus Link Solutions’ MQTT Modules are a perfect pair for easily establishing a unified namespace architecture for your real-time data. As a single source of truth for data consistency and accessibility across all your systems and applications in Ignition, UNS standardizes how data is named and shared. The result is improved data management, administration, security, and visibility for your operations.
Gain Deeper Industrial Insights With Data Analytics
You don’t need a crystal ball to predict the future and prevent problems. Practically self-monitoring, Ignition gathers live data and feeds it into analytics tools that combine it with historical data to develop insights. Reduce resource and fuel consumption, forecast sales growth and production needs, or schedule preventive maintenance — it’s all possible. Then, use the OPC UA Module or SQL Bridge Module to connect servers or databases and share insights.
Spark Connectivity, Compatibility with Open Standards
Extend your IIoT solutions with Sparkplug B, a payload specification that leverages open standard MQTT to connect edge gateways and devices with business apps and other Industrial IoT applications. As an official Sparkplug Compatible software platform, Ignition makes it easy for you to share contextual data and metrics, regardless of vendor or software affiliation.
Learn more about Sparkplug®More Features
Do Even More with Ignition IIoT
Third-Party IIoT Platform Integration
Full integration with other IIoT platforms: Azure, AWS IoT, Watson IoT, and more.
Exceptional Redundancy and Security
Security, disaster recovery, and high availability are native capabilities of MQTT infrastructures.
Seamless Integration with Ignition SCADA
All Ignition solutions work seamlessly together for easy system integration.
Dynamic Reporting
Create a full range of dynamic, data-rich reports and send them anywhere.
Alarming Notification
Set up an alarming system that sends notifications to you through email, SMS, and voice.
Industrial Historian
Turn a SQL database into a high-performance time-series tag historian.
HMIs and Dashboards
Create high-performance HMIs and enterprise dashboards to display your data.
Get Mobile Access
Get mobile access to your industrial applications via smartphones and tablets.
Instant Installs and Updates
Install on a server in just 3 minutes; push updates to clients everywhere, instantly.
Totally Cross-Platform
Works on Windows, Linux, macOS, and more.
Concurrent Web-Launched Designers
Comes out the box with the industry’s most powerful IDE—for free.
Unlimited Clients
Deliver data to anyone without additional costs.
